ok got this code...caused by comp?
Old 09-29-2006, 07:59 AM
getblown5.9's Avatar
Originally Posted by Bart Timothy
You're running a Drag Comp. That, along with the hot TST, and RedLine, are VP killers. They over work and take out the fueling solenoid, causing the P0253 code. This is another example of a non fuel pressure related VP failure. If you want to play you got to pay.
does a regualr comp/TST have this same effect?
also if were to switch to a standard TST program, then stack a smarty for the above 2700rpms fueling...would this still put the same strain on the solenoid?
Old 09-29-2006, 09:56 AM
Bob Wagner's Avatar
I believe the competiton version tst is normally set at 75% duty cycle. You should be fine
Old 09-29-2006, 10:18 AM
well after i finally come up with the money for a new VP, i plan to some day get a TST/smarty stack. id just hate to think that i'll be one of the unlucky people who repeatedly kills VP's due to the fueling box and not due to fuel pressure since i run a fast with garden hose sized lines, and never see less than 10psi WOT
Old 09-29-2006, 12:18 PM
BigBlue's Avatar
Look at me. I've run a comp, TST, smarty, run the pump on low pressure, run the tank low, switch additives all the time, tapped and untapped the wire several times and mine's still ticking along. I say get your injection pump warrantied. You might not get the hrvp but at least you won't have to worry about coming up with the money. That's what I'd do. If it fails again then get the hrvp if you have the money. Like you said, you just spent a butt load of money on the truck and it would be a shame to take it all off. Just warranty the VP and save your money for something else. When it rains it pours but once it dries up everything is that much better off.
Old 09-29-2006, 12:35 PM
well my cummins engine warranty expires 10/25/06...so i have only a short time to get it fixed
2500CTD
57
12-07-2004 03:15 PM
cumminsdriver635
05-01-2004 10:41 AM
erics76
03-16-2004 09:09 PM
Sittenbull2
16
10-16-2003 07:21 PM
WTTD
06-05-2003 09:45 AM
Quick Reply: ok got this code...caused by comp?
