oil return hose on HX40
Old 04-02-2003 | 08:05 AM
yrusoslow2's Avatar
When i put my HX40 on I had to modify the oil return hose to make it fit. I cut the metal tube and put a longer piece of rubber hose in place of it. My problem is the only 7/8&quot; wire wound hose that I could find was not rated to hold oil or fuel. Does anyone know where I could find 7/8&quot; hose that will work or has anyone else had to do this and what did you do to fix the problem. Thanks for any help.<br><br>Justin
Old 04-02-2003 | 08:18 AM
PourinDiesel's Avatar
Re:oil return hose on HX40
Justin,<br><br>First, make sure that your turbo's drain opening is clocked properly.<br>Then, I would adjust your metal drain tube installed in the engine block by using a rubber mallet or placing an object in it and orientating it in the direction in which you desire.<br><br>Then your rubber drain hose should line up perfectly.<br><br>--Justin
Old 04-02-2003 | 08:44 AM
hellotbone's Avatar
Why did you have to mod the oil tube? COuldn't you just clock the turbo to line up?
Old 04-02-2003 | 09:25 AM
yrusoslow2's Avatar
I did clock the turbo but the problem that I ran into was where the oil drain line mounts to the turbo. When i tried to bolt the tube to the turbo the tube would hit the turbo. I cut the tube and mounted it in the other direction so the tube was facing towards the fender then ran a hose from there to the motor. I was told that the oil return line on some years was shaped differently. I looked at my buddies 2001 and it was different than mine. My HX40 is not from piers so I am not sure if they do something differnt on theirs to fix this. I just have a stock 40. What I did is working fine I just need to find some hose that can be used for oil.<br>
Old 04-02-2003 | 04:59 PM
Jamie,<br>Mine was a little off on orientation since it was new.<br>Just a little trick of the trade.<br><br>--Justin
Rick 12v CTD
09-23-2011 06:21 PM
Scotts_D250
07-10-2011 02:05 AM
ctd4stan
05-18-2009 03:56 PM
Necred
10-05-2007 09:02 AM
Hawkeye
09-23-2003 09:22 PM
Quick Reply: oil return hose on HX40
