oil presure question Edge Juice
I just installed a juice with attitude. The oil presure gage in the truck reads 60 psi at idle. The juice reads 25 psi at idle. Is this normal. The rest of the gages in the truck read pretty much the dame as the juice. How accurate are the juice gages. Thanks
I've found the edge gauges to be very reliable. my oil pressure in dash and edge are the same or close...I believe Edge gets it oil pressure reading from the ecm and so does the gauge in dash I'd think the indash gauge may be suspect...althoughj 25 seems low i'm at 70 at start up and drop down to 40 or so after warm up and run
60 is a lot closer to mine than 25 I would say that it is the juise that is off.
MrSuzuki
08-25-2009 08:22 AM
razor6
22
01-20-2006 04:43 PM
djcheez
10-15-2005 05:13 PM
