Oil Pressure Gauge ...question??
Originally Posted by Rattlerattle
Is a 0 - 100 PSI guage the correct range for oil pressure?
Thanks
Thanks
The pressure reading from the top of the filter housing tends to be about 15-20 psi higher than the stock gauge.
Does anyone else concure with the Doc's idea that copper does not flex, i thought itwould be ideal, but if he is right perhaps i'll have to think again, when you buy brake pipes here in the UK you can either get a copper mix metal or plain copper pipes, all our domestic central heating pipes are copper( i know it's not the same thing ) but they are exposed to high temps, what is the best solution, i will go with the majority............ade
I don't have a problem getting hydraulic lines made up, just need to know material to be used, and i was just being economical as i had some spare tubing in the garage
Plastic 1/8" tubing works for me. If you want a higher quality than comes with the gauge install kits buy 1/8" air brake line and push it though some 1/4" tubing that will form a protective sheath against kinks, cuts and abrasion.
I find that hydraulic or braided line to be too hard to route around especially if the gauge is in the A pillar. Line with the braid on the outside tends to saw though anything it touches.
Originally Posted by infidel
You might peg it on a cold winter start, 120 psi would be better but hard to find.
The only gauges I've ever seen that weren't compatible with most everything except strong acids are oxygen gauges.
Did you check out the gauges here> http://www.surpluscenter.com/sort.as...s&keyword=NFGA
Only $8 for this Stewart-Warner gauge made for Freightliner
Did you check out the gauges here> [url]
I also ordered an AMI 0 - 150 psi air pressure guage for if I one day get around to OBA. Might just use it for oil pressure as it would be more reliable than the factory one.
Thanks again.
OK so it's plumbed in, after a few minor leaks, it reads 75psi on cold tickover, it's about 16deg C here today, 85-90psi at crusing speed, and 55psi when warm at tickover, does not seem to be to removed from the OEM dash gauge.
GlennRMK
05-24-2007 10:46 PM
Matt Lambrech
01-28-2007 04:13 PM
Ripper01
04-11-2006 09:10 PM
streetsmoker
02-22-2006 06:47 PM
