oil cooler gasket
Re:oil cooler gasket
Thumper,
Just call your local Cummins dealer and they will ask for your Engine serial number when requesting this part.
That will get you the right oil cooler gasket you are looking for.
For an ISB 24 valve, you should have a Metal and Rubber gasket, for the Oil filter housing it should be a Metal/crush synthetic material.
--Justin
--Justin
Justin,
thanks i'll try that mon. am ...talked to thir teck support friday , they did not know,.. so i'll try the back door aproach tomarrow ,,see if they can do it that way....seeems like a good idea to me
thanx
thanx
That number you have posted is an engine serial number correct? (looks like one according to that 565....)
Here are some part numbers that will get you what you are looking for:
Oil cooler core gasket 3942914
Gasket filter head 3942915
--Justin
--Justin
once agan Justin you come to my resque. i'll have them look it up NOW. thanks
george
OK OK OK DID THAT..it' the gasket with the slot in it!!!!!!
YEAAAAA 8) 8) ;D I hat e mysteries, mesories and the like!!
george
