OEM air filter
OEM air filter
have a 4" exhaust and a K&N air filter. having read some negative posts about K&N filters i plan and taking it out and going back to the OEM filter that the ******* sells for the CTD. my question is do any of the gear heads here see any problems with this? i know i will loose some of the power but more concerned with letting the bad stuff in with the K&N. also i know the K&N needs a bead of sealer before putting it in, what about the OEM, do i just drop it in?
thanks,
david h
thanks,
david h
Re:OEM air filter
on the above post i mean is there a problem with the OEM air filter and the 4" exhaust? on my old 74" harley the intake had to be tuned to the exhaust. i know old harleys but nothing about these CTDs.
thanks
thanks
Re:OEM air filter
Well you didn't tune the exhaust to the air flow when you put on the 4" system??? So it really doesn't matter. I would throw away the K&N filter, but if you are saying with the stock air box, Go to the AMSOIL filter, they seal good and are not very expensive (27.00). And open the stok filter box with a few good size holes in the sides. Or, throw the whole shbang in the trash and get a good AFE maga cannon filter set-up, this is what I did and I pretty much went the same route as yourself.
Re:OEM air filter
The whole issue with the stock air box is two things: One being that it is very restrictive, even for a stock motor. And two is that if your not carefull the air box can leak and let in more dirt. So drilling out a stock one is ok if you want to stay with stock, but you can never take it to the dealer with a hacked air box if your worried about the warranty. But you can get an aftermarket one and then quickly swap before any dealer gets under the hood. As for the K&N, well I dont really know what to say about this subject except that I had one and then got a Megacannon. Not cause the K&N wasnt doing the job but because the stock air box couldnt flow the cfm. After market filters flow more because the lack of the stock air box and they have more filtering surface area. Doesnt have to be an oiled design. Some people get the BHAF. Its paper. It seems to be more personal preference than fear. Personally I have never experienced any problems with K&N but I really like the aFe filter I have now. If anything, I would stay away from the stock filter if EGT's are an issue with your truck.
No you dont have to tune your motor. Gas engines are not like diesel engines. They dont require the correct fuel ratio that gas needs. They work like a furnace. More fuel = more power. But with more fuel you need more air (boost) to feed the flame for better combustion and lower EGT's. Do some research on how these motors work. Its very interesting. Hope this helped.
Re:OEM air filter
Here are some part numbers.
Fleetguard AH19037
NAPA 2790
WIX 42790
Donaldson B105006
Baldwin PA2820
Hastings AF1012
Fleetguard available from any Cummins or Big Rig distributor.
NAPA I assume is from Napa
Not sure where the others come from, probably any good auto supply store could get one.
I have the Fleetguard version, purchased from Cummins Intermountain in Salt Lake City, for right around 50 bucks.
phox
Fleetguard AH19037
NAPA 2790
WIX 42790
Donaldson B105006
Baldwin PA2820
Hastings AF1012
phox
Re:OEM air filter
I'm not sure where to get the BHAF. I think Napa sells them. And I think the Cummins store sells one. Maybe someone will chime in and let you know where and the part number.
SKATERHAULER
10-02-2013 06:34 AM
p0wd3rp1l0t
18
09-02-2007 10:49 AM
BAJA MAN
11-21-2006 05:49 PM
