O-ringing
Old 03-23-2005 | 12:13 AM
BDR2500's Avatar
Arrow O-ringing
Would I need to o-ring my head if I were to run a PDR HX-40 gated at 40psi? Or would there be somethin better instead of o-ringing? I wouldn't want to keep going through gasket after gasket. Any idaes, opinions, or help would be great.
Old 03-23-2005 | 12:25 AM
Don M's Avatar
DTR Advertiser
NO, ARP studs and your set.
Don~
Old 03-23-2005 | 02:38 AM
BDR2500's Avatar
So the stock head gasket will hold?
Old 03-23-2005 | 08:06 AM
Jetpilot's Avatar
The stock gasket will be fine. I do agree with Don though that adding the ARP studs will certainly make the truck completely reliable.
Doug
Old 03-23-2005 | 09:10 AM
mcoleman's Avatar
I've been running 40-43 pounds for quite some time with no problems. The only reason I don't have studs is ARP ran out. They will be installed shortly though.
Old 03-23-2005 | 10:01 AM
Beast2B's Avatar
I've been maxing out at 45-46 lbs for six months, no ill effects yet with stock HG and bolts (knock on wood)! Studs are in my short list.
Don, what is your suggestion for max boost with stock HG and 12mm studs? I know it varies, just not sure how much it changes!
Thanks
Old 03-23-2005 | 02:22 PM
BDR2500's Avatar
Thanks for the help fellas, I'll be sure to add the studs to my list
2whistlers
01-31-2005 08:54 AM
2whistlers
01-21-2005 10:52 AM
swank
11-24-2004 09:25 AM
TXram
11-08-2004 09:15 PM
GO 4LO
19
05-05-2004 04:25 PM
