O-Ring job
O-Ring job
What is a decent priced to get a 12valve (2nd Gen) head o-ringed. I finally filled the cooling system with oil. It took 58psi of boost and a couple stages of nitrous.
Registered
To deck, cut, and install rings in your head should be $300-$400 at most shops (you pull you re-install). If you need valves & seats ground and giudes it well be more.
