O-ring or Fire ring???
so what your saying is that orings can be cut into the block or the head???
i'm swapping my 53 block out of my 98 truck for another bottom end next summer, and i was going to oring the head at the same time.... but if i could have the block i have sitting here oringed that would save me some downtime...
Thanks for the reply's, I've learned a lot. I dropped my head off today to get Fire rings installed (that's all they do) the owner of the shop says he's got 40 or so trucks running around with this head setup with no problems. He also told me that he does the same setup whether you're drag racing, sled pulling, heavy towing, or just street performance. Anyways, at least now I can put my twins on without worrying about how much bosst it makes! Thanks again
DH
DH
We've been oringing the block for awhile now, even with the block in the truck. It's held up to incredible abuse from insane back pressure and nitrous. Keep 'em torqued and the quality of the machine work high.
brandon.
brandon.
IF your making the same power and you deicde to o-ring or fire ring it one day, it wont change the drive-ability of it. I never understand it when people talk like that. Or only 500 hp is driveable. what the heck ever
so the main reason most oring the head is because its much easier to take out of the truck than the block.... correct?
so correct me if i'm wrong.... there is no difference in install if you oring the block vs: oring the head?
I have seen guys use a BHJ with block template to cut the groove in the block.
What installation differance are you talking about? Just installing the head, cutting the groove, or installing the wire?
i just mean does it work exactly the same way as if you oringed the head?
just install the wire into the block instead of the head, put gasket in, put head on and studs....
is it any harder for the shops to cut the block for orings than the head?
I do know of a couple shops that will cut grooves in the block but you have to have it out of the truck.
O rings in the block or the head... They both work the same for assembly.
For the average guy I would just oring the head.
well what i'm doing is swapping blocks basically... because the block i'm swapping in for the 53 block is out of an 89 so the head on it has the 9mm injector bores... so i'm going to use the head thats in the truck on the 53 block....
the block i'm swapping in is sitting on an engine stand in my garage....
I do not know of any shop in Utah that has the tooling to cut grooves in the block with leaving it in the truck.
A local shop (PDI) does fire rings, but not o-rings. Jetpilot (PDW) said in his opinion that fire rings aren't as streetable as o-rings. I drive my truck everyday (100-150 miles) and I don't want something that is going to fail like my stock HG did. What do the masses think?
As someone who has had twins ,and driven 75K miles on them,for over 3 yrs,I would not be doing this stuff to a truck you need to run 100-150 miles a day reliably. Twins are awesome,but eventually your going to lose a head gasket,if your lucky,only once every yr or 2.You will also loose plenty of exhaust gaskets,and just have more things to go wrong.Id have a backup mode of transportation available if i were you,just speaking from experience here.
Many of the guys who run twins,do not drive these trucks daily or very limited miles.If i had it to do over,I would not have twinned my truck,although I change my mind everytime i plant my foot on level 5
