O.K. Dumb Question.... Head Studs - LOOK Inside :)
What is the difference between studs and bolts?
I know studs hold more PSI but how do you install them?
Do regular bolts stretch?
At what PSI (boost) are the stock head bolts and head gasket good for?
Are they just screwed down to a certain depth?
What size does a 12v use?
Any other info you can give me?
What is the difference between studs and bolts? a bolt is one piece, a stud is just that, a stud screwed in the block with a nut and washer on top. due to this design and the use of stronger metals, the stud can achieve much greater clamping force as well as resist the forces to stretch and allow pressure to lift the head from the block in high boost/high hp applications.
I know studs hold more PSI but how do you install them? stud gets screwed in into the block once the head is on, then a nut and washer go on top
Do regular bolts stretch? yes, studs can stretch too, but its takes alot more force
At what PSI (boost) are the stock head bolts and head gasket good for? as a rule of thumb, about 45psi...but I have heard of some DHRA race trucks running stock HG and bolts, with lots of proper retorques at 60,70 and even 80+ PSI
Are they just screwed down to a certain depth? head bolts go in until the factory torque spec is met, studs go all the way to the bottom of the hole and back a half turn so they arent bottomed out. more threads of engagement for strength
What size does a 12v use? 12mm
Any other info you can give me? If you put studs in, be sure torgue them properly and prolly check/retorque them once a year after that unless you are running high HP and high boost, then check them more often
Also, what is fire ringing, o ringing? On a HG there is a metal fire ring around the cylinder that seals the pressure in. Fire-ringing removes this ring from the gasket and places a large and heavy ring in the block or head to seal the cylinder. O-ringing is when you cut a groove (usually in the head around each cylinder) and put a small wire in the groove. When torqued down this ring which sticks out of the head a few thousandths of an inch put alot of extra clamping force on the fire ring part of the gasket, which heals to seal the cylinder better in high boost, high power engines.
Whats it do?
Whats it do?
Here you can see the o-rings i had done on my head around each cylinder
10char limit
Getblown5.9 hit all the nails on the head, with pics too! lol. Whenever you install studs make sure to bottom-tap the threads in the block, you will get an extra 1/2-2 turns out of the stud if not more...
12valvetom
11-28-2009 12:37 AM
dieselboy59
01-30-2009 04:57 PM
smokewagon
08-08-2008 10:54 PM
MikeThomas
05-11-2008 12:39 PM
jmccart
21
05-14-2007 12:47 PM
