nv4500 rebuild ?
Old 08-17-2007 | 09:10 AM
ajoebob's Avatar
Question nv4500 rebuild ?
i am going to replace my clutch and was thinking about rebuiding my tran wail i had it out.
i have a little growl in 5th but it shifts good.
where is a good place to get parts. i dont have much to spend on it.
or sould i just leave it alone?
Old 08-17-2007 | 09:45 AM
blackdiesel's Avatar
Registered
I would leave it alone. And change the fluid with some good stuff. JMO
Old 08-17-2007 | 08:42 PM
Big Blue24's Avatar
Blackdiesel, what fluid is the good stuff?
Old 08-17-2007 | 08:57 PM
1-5-3-6-2-4's Avatar
GL-4 synthetic gear oil.........it has to be rated GL-4.
Old 08-17-2007 | 10:43 PM
Registered
That's a mater of opinion. Some say redline, some say others. you be the judge.
displacedtexan's Avatar
I would use the Castrol stuff for it, from Dodge or Chevy dealer...
You can't use off the shelf gear oil in a NV4500.
Old 08-17-2007 | 10:47 PM
Well said Brian. I already stated what I would do (and did to mine) but this one aint mine
Old 08-18-2007 | 10:47 AM
Big Blue24's Avatar
Reason I ask is mine is always wet, even after my recent rebuild so I was wondering what to replace/ refill with. It does have the stock Castrol Torque Syn or whatever it is called in there now.
Old 08-18-2007 | 10:56 AM
Mike D's Avatar
I talked with a re-builder who said he recommends using 10w30.
Old 08-18-2007 | 11:58 AM
300sd2500's Avatar
^^^^^^^^^was he a rebuilder of transmissions?^^^^^^^^
Old 08-18-2007 | 05:57 PM
Tate's Avatar
The Castrol and Amsoil are the only oils I know of that are made for the NV4500. Every time I've drained the OEM oil out of a tranny, its been a nice honey coloured. I ran redline in my tranny after I did my dual disc, and other than the synchros getting eaten, the oil is black black black!
Old 08-18-2007 | 07:38 PM
Penzoil makes a GL-4 rated synthetic gear oil. I have it in my 4500
http://www.pzlqs.com/Tech/Pdsheet/Do...E75W90GL-4.PDF
Old 08-18-2007 | 08:35 PM
linetrash75's Avatar
Now to cross reference that GM part#12345371. And see if it comes up fluid for NV4500.
Jed
Old 08-19-2007 | 05:18 PM
Tate's Avatar
Castrol Syntorq LT® is available in quart bottles from Dodge dealers (p/n 4874459) and GM dealers (p/n 12346190).
That penzoil stuff is a substitute for GM P/N 12345371. So while that stuff may work, its not designed for the NV4500 like the Castrol and Amsoil oils.
Old 08-19-2007 | 05:46 PM
How so?
If you read the info page in the link it says it is designed for brass and other soft metal syncronizers.
Can't see that posing a problem.
