no more boost
no more boost
I just installed my #5 tst plate. I also put the elbow in on the line on the turbo. I am now still only running 18psi and was wondering if i have done something wrong that would keep boost from getting to about 25-30 psi. I have done everything that i can think of that may be a problem. If you guys have anymore suggestions i would appreciate them. thanks again.
-Gary
-Gary
Does the truck feel like more hp or still stock?
Does the engine smoke? Sign of fuel, but no boost.
Did you slide the AFC housing forward and spin the starwheel? The AFC will limit fuel which limits boost.
Forget to tighten the band clamp on the boot after installing the intake? Get the gasket in the intake? Forget a bolt?
-Gary
Try removing the boost elbow and plugging the compressor housing. That will tell you if the turbo can produce more boost. It it does, then the elbow needs adjusting.
If not
the wastegate may be stuck
charge air leak at intercooler or couplings.
Unless you added an AFC spring and ruined the diapgram it should not leak. Possible it did rupture, too.
If not
If not
If not
-Gary
