no boost on twins
no boost on twins
Got new turbos on and they will not build over 35 psi. Put a smoke machine on it and none of the boots are leaking, closed off the waste gate and no more boost. Getting pleny of fuel and nothing above 35 psi bigg pull for me on sunday and truck is runnin like a terd. need as much help as possible asap thanks everyone.
I didnt read anything over 43 psi with my juice w/att. I swithched to the ADR and now I have 60psi with a litte more but I havent taken it that far yet.
Been out beat'n on the truck for the last hour and can get the truck up to 43-45 psi. Is that all I'm gonna get? I still pull a 30' trailer, will I be able to keep the pyro in check with that hooked up? I thought when bought this the pyro would go down but haven't seen that yet, any thoughts.
I've been reading some old threads and wondering do I have enough fuel for these turbos or should I be going back to a 62 of some kind for better all around use. These turbos have all kinds of big end but seem to lag a bit out of the hole but maybe that is normal I do not know.
I really dont know. Some 150's may do better but I cant promise you. Too big and they will be really hot but if you dont spool them they will be hot too.
How are you reading the BOOST????
If it is through a box, that read from the factory map sensor, I have heard it won't show over 35-40. Get a new guage and read it.
You may have higher boost and it isn't recorded!!!!
well i have a question? I dont have twins although I would like to eventually but , I do have a superchip plug in box (older one) and my boost guage will hit 30 psi if I really get on it, I am wondering if my guage is reading correctly , I have it tapped right into the top of the intake near where the heater grid is (well about 8 inches away)it seems legit but now I am wondering
dodgediesel
17
04-05-2011 11:21 AM
Stock 02
28
09-24-2006 11:09 AM
stlsparky
11-21-2005 10:02 PM
