Nitrous Oxide w/o headwork??
Can a guy get away with running stock HX 35 gated at 34 psi, Juice/ Att, Edge Jammer 5's, and 40 HP shot of Nitrous to clear up the haze with a stock head gasket?
Just wondering if anyone else out there is running a "turbo in a bottle" with stock head gasket and bolts?
You need head work to run Methanol. It causes too much cylinder pressure and will pop any stock head gasket with enough time and or abuse. Just a little H20 can be sprayed to cool egt's without head work for a while, but eventually it too will cause head gasket failure.
Yeah. Nitrous will raise cylinder pressure just as much as water/meth and will do the same amount of damage to a headgasket. There's a reason people upgrade turbos and headgaskets before doing nitrous.
nitrous will raise cylinder pressures, but a 40 shot is realy only like adding about 4psi of boost... probably won't hurt anything w/ that small of a shot.
methanol adds a lot of timing, that's why it's so hard on head gaskets
Mike D
87
04-10-2008 03:18 PM
Tartarus
10-20-2003 02:59 AM
