nice cheap turbo
Sweet link man, that explains alot. I know the function of a Turbo, now I know the parts. Ill head to the junkyard as soon as Uncle Sam is done with my skinny ****. Now, if you feel up to answering a few more dumb **** questions, what seperates one turbo from another? I know its size, but size of what? And what are the standard sizes for the different applications?
Im looking to get most of my power in the lower RPM range. Most of what I do is off the track...off the road...and normally off the trail.
If your looking for more grunt down low then you should rebuild what you got or some type of hybrid or twins, a bigger turbo will only make you laggy down low without more fuel, anything smaller will not cool EGT's good.
here is a decent price turbo http://www.citydiesel.net/dodgezilla...cPath=22_27_50
Joe
After that last run of bad cams, they should have used Volvo engines. Where are you in Pa.....I'm about 50mi east of Pittsburgh
![Talking](https://www.dieseltruckresource.com/forums/images/icons/icon10.gif)
what everyone seems to have missed here is his path to upgrading in stages. Turbo shouldn't be near the top quite yet.
Gauges gotta have gauges, FP,Boost & EGT
Fuel system upgrades
Tranny if Auto VB and TC clutch if stick.
Comp or Smarty or something else.
then
Injectors and Turbo.
Anyways that's JMHO and .02c
Don't want ya to have too much air and not enough fuel. But if you already have most of this stuff i didn't know because it's in your sig.
then
Ok, sounds pretty good. Could ya be a little more specific on "centersection"? Im a bit new to turbo's, does that mean housing? And what is a good brand/source for these parts? Would the upgraded turbo be on par with say a jammer BB?
My goal is 350 -400HP, but Im doind this in stages. Stage one is intake, intake manifold, exhaust manifold, turbo and exhaust. Stage 2 is Aux pump, Injectors and chip. Stage 3 is tranny upgrades, suspension, cam shaft, fancy stuff.
I want to get all of stage one done in one bang, which means saving cash on the turbo. So the upgraded HX40 would be good for all this?
Thanks a ton grease monkies, think Im becoming a convert.
What tranny you got? If you're only looking for 350-400hp.. I'd look at a hybrid if you got an auto. HX-40 if you got a stick.
I am about 20 miles west of Chambersburg. It wasn't the cams that were the problem the oil holes in the block didn't intersect. The volvo engines aren't bad but I think the Mack engine is better. Sorry for hijacking the thread guys.
Joe
Joe
rowley_141
07-20-2008 02:02 AM
Dean Snow
09-25-2007 12:29 PM
