Next phase in building my truck...3 weeks to do it!
As of right now I have a little under 3 weeks to figure what next im going to do to my truck, there is so many options and I don't wanna throw money away at things i dont need right away.
I replaced my HG the other weekend and will have studs here soon but i wanna find out what the deal is with my truck.
For having the mods i have im surprised that im not smoking more than I am...With Edge all the way up and boost levels at about 20 psi + it will smoke a bit but im a little disappointed in overall performance
Max boost im reaching right now is ~ 43 psi
Im thinking I need a new turbo to cool down EGT's a bit but i still need more fuel too somehow to get more smoke.
I dont have a ton of money but wanna get the truck all set up for Eric Merchant's Spring Fling and show a bunch of the Duramax guys what a real motor is!
I know all of my questions are kind of all over the place but i wanna build my truck up right, not throw money away.
Should i get a FASS before upgrading turbo?
Programmers...im tryin to hold of right now on that because i figure for now i'll use my edge but am thinking of a smarty stack here in the future ??
Two things diesels need...Fuel & Air, i just need help on maximizing the best bang for my buck & figuring out what works & what doesn't work for the 24V.
Thanks guys!
Thanks guys!
Head Studs & O-rings are a good idea, im kind of on the edge of the acceptable boost levels for stock turbo & stock head bolts right now maybe i could push 50 + psi but thats not a chance i want to take & with what i want and what i've got.
I'd like to start building up with the stuff that will be able to withstand all the power i throw at it in the future, head studs are a must.
I blew my head gasket a few weeks ago running water/meth injection...I would have done studs when i had the head off but it was memorial day weekend and nobody was open so i slapped the head back on and called it good.
This being a straight 6 motor I can put studs in without having to remove the head here in the near future...im not sure whether you can do that with the V-8 diesels or not, i've never done them on a duramax or powerstroke but have done them on V-8 gassers & always have had the heads off.
Hope to see you at Merchants, i know you've got a fast truck duratothemax...i've heard alot about it on the diesel place.
A 50hp cam? Never heard about that. Anyways, the cam is probably helping get more air in and out and that's what's causing the low smoke levels. That or your injection pump is on it's way out. Smoke is just lost power anyways so be glad you don't have any. I'd get a new turbo and lift pump setup and then you should be good to go. Oh yeah, get studs.
ya Ill be there...but my truck is peanuts compared to the big dog dmax's and CTD's that are going to be there. Im looking forward to meeting all you guys...its always cool to put faces with forum names
ben
ben
Lift pump- whatever works. 22 psi is optimal for max power
Then add a quality injector like a ddp5 or mach 6/7
finally add a 66 or 71mm turbo and you've got a proven high power setup.
ZombieSoldier
15
11-08-2010 10:05 AM
halerazor
Competition / Pulls / OffRoad
14
09-25-2006 06:59 PM
