newbie nozzle question
I've been seeing lots of happy CTD owners saying I should get some really expensive injectors, but I wonder if I really need to go so far.
I run a '02 24V mostly stock (about to add BHAF). I pull a brush chipper (less than 3000 lbs) and carry a load of chips most of the time (maybe 2 yds, crazy high est. 5000 lbs) and I'm not that concerned about smoking other trucks at stop lights. I would like to see some better mileage, though.
I saw this site with some RV 275 nozzles for a couple hundred. It claims I'd see increased power and mileage with decreased EGT. Would this be worthwhile for me? Would I need to do anything besides just pulling one set of nozzles and sticking in the other?
Again, I'm not looking to drag race or pull a house--just regular medium-duty working truck for my tree business.
Thanks in advance for any advice.
Keith
note: I have no connection to the site linked above. It was recommended by people at Fred's TDI club in relation to my wife's TDI beetle.
Keith
Last edited by treedweller; 06-21-2006 at 05:27 PM. Reason: add note of no affiliation to site
RV275's are always a popular upgrade for a small power increase. If you check the classifieds on this website you will see a complete RV275 set for $200. Much better than just getting the nozzles for the same price. Eric
Consider a VanAaken
That is what I used to run and improved mileage 1.5-2 MPG.
My injectors did not help my mileage, if not hurt it a tad.
Also exhuast will help as well.
I started w/ a VA5 for a couple of months. Then put in the Jammer III's. Major difference. Although the clutch is not happy. If just looking for a mild upgrade then a VA or an EZ would work good. I have heard a lot of good about the Smarty but they are more expensive.
CJ
CJ
Thx for the input so far.
I'm really working over here to digest all the info this site has to offer.
I'll keep reading and post more questions later (probably).
Keith
Keith
Keith
Keith
CJ
I think you would be better off spending money on a programmer or box.Injectors are basically the next step after that anyways.The smarty can be used for anything,it would accel at towing i would think,it also has a fuel saver option.It isnt cheap but probably the best all around box.It gives unimaginable throtle response and drivability compared to stock,no one complains about the smarty
sheriffav8r
09-15-2008 09:35 AM
