newbie - which bombs first...
yeah disconnect them from the injectors and the pump, remove the air intake horn
and disconnect the grid heater cables. then you should be able to get to it. when putting the return line on start with the middle bolts and work your way out it'll line up better and make sure your injectors are tight and forget the torque spec on them mine leaked too until i just tightened them down as tight as i could
sledneck1
15
12-11-2007 02:25 PM
CODODGE2500MAN
29
09-08-2006 01:03 AM
rottenron
07-14-2004 03:26 PM
