New Truck, whats first??
Old 04-26-2006 | 06:59 PM
cowboy717's Avatar
hey guys,, just got, my new to me 02 sb qc, its an auto 4x4, want to know the first things to put on it, i've got a bad itch , to smoke alot of ricers and frat boys around here before i leave, i graduate college may 13th, i've heard gauges are always first,, what gauges do i need, i will not be towin much, just haullin butt,, its already got an 80 hp box on it,, i don't know the type, its set up to where i can turn it on and off by a toggle switch
any help for a newbie would be greatly apprieciated!!!
thanks in advance
Cowboy
Old 04-26-2006 | 07:04 PM
P.J's Avatar
P.J
Fuel pressure (must have), pyro & boost (boost being the least important)
Congrats on college.
Old 04-26-2006 | 07:21 PM
seabee's Avatar
congrats on the new truck . well like he said get some gauges fuel pressure is a must on these trucks if it drops below 8psi you could hurt your injection pump .also on the gauges you will want to get a boost ,pyro and a trans temp since you are running a auto. if your trans is in good shape now you might want to look at putting a vb/tc in there so you can start building more power . the stock tc is a weak point in these trannys . if you are on a tight budget get your gauges then get a vb or shift kit from like dtt or goerand . happy bombing the search for more power will only end when you let it
Old 04-26-2006 | 09:31 PM
TxDiesel007's Avatar
thanks in advance
Cowboy
I did the same thing u did...
spank the ricers and frat kids, and cover them in soot in the process a time or two good feelin before u graduate school. Anyways congrats on your accomplishment, and good luck finding a job, Lord knows ull need it, i finished in december....
Gauges first, then u can get some more goodies, exhaust, intake, you already have a programmer, then u can get injectors, and really lay a hurting on them... and more so get some air!
Rick
Old 04-26-2006 | 10:28 PM
otter's Avatar
thanks in advance
Cowboy
Got an 02 myself and although I do not have huge horse power, I have made a few mistakes along the way...... Gauges and Air, then go for the Tranny. It's the expensive one but from what I have found here you won't regret it. I am going through the same problem myself as we speak.... DTT, Talk to Stephan. Good luck and run that 02 hard.
Ramking10
09-27-2014 01:32 AM
Bobcat698
05-24-2007 12:01 AM
flashgordon
03-26-2006 02:27 AM
The Domie
01-06-2005 03:23 AM
spassey
01-25-2003 01:08 PM
