New sticks
New sticks
I got a set of Bosch 300's Im going to install... I havnt installed injectors on a 24V since the came out.... Does anyone have any tricks of short-cuts they would like to share???
When I did mine I did them one at a time. The only exception was on 3 & 5, I had to loosen both injector lines at the same time to get them out because of how the lines were clamped in the same location. When I installed the new ones I took a wrench and put in the grove on top of the injectors and kind of turned them back and forth a little so the supply line would seat in the injector. Pretty easy and straight forward swap. Good luck. There is also some good info in the tech section of this site.
Well I got them in. Took about 1.5 hours thats including a few smoke breaks. I dont think I could of picked a hotter day to do it though.
Took it around the block, but I couldnt get too hard on it as there are so many kids around playing... I will take it out later and see how they perform.
I noticed already that it runs smoother and idles quieter...
CD in NM
07-10-2008 12:16 PM
ramroamer
03-13-2007 12:13 PM
hotdram
05-23-2006 05:22 PM
