New Stealthy exhaust--WOW quiet
Installed a new MBRP 4" turbo back exhaust with muffler and resonator this weekend. Install went well; I cut off the hangars on the old pipe to make getting it off easier. The hangars are definitely the challenging thing on this exhaust install. Using long bolts to get the downpipe attached was the trick for me, then I just snugged them up and changed out to the new bolts.
I want a really QUIET exhaust...I want to be able to talk on my cell phone (bluetooth) in the cab--whoopee. I also tow horses so I wanted a very quiet sound out of the tailpipe. So, I installed a 30" resonator (5" diameter)
The resonator is wide open, but there's a spiral design...does something to decrease the sound. I installed it as close to underneath the cab as possible, right after the downpipe.
Anyways, the sound is exactly what i wanted.
No increase in EGTs, no drone...my truck sounds HAPPY!
This is the opposite of what most people want,
but if you want stealthy this is IT!
Got it here: He also makes 'em for the 5" exhaust systems
https://store.ftediesel.com/home/vie...1&idcategory=0
I'm like you. The MBRP wasn't terribly loud in the cab, but I knew I wouldn't want to tow with it. I replaced the MBRP muffler with a 41" Donaldson. It's a little louder than stock outside (sounds better though) and on the inside it is quieter than stock. Maybe it's just me but I believe I'm getting less engine noise as well.
Over a couple of tanks of fuel, I'm seeing a 1.5-2 mpg increase as well. Gotta like that!
I added it into my MBRP turboback exhaust w/muffler--so I have the resonator + the muffler
I added the resonator where a catalytic converter would be if you had one of those...
MBRP makes a resonator too, and its priced comparative to the FTE Diesel unit;
but I read such good things about the FTE Diesel unit I wanted to try it
and especially since they offered a longer model--the 30"
FTE Diesel was very helpful on the phone, and shipped quickly.
re: MBRP resonator...I didn't find anything when I went looking, so I didn't hear good or bad...
i also wanted a quieter exhaust after driving with my 4" MBRP for a couple years. i simply removed the MBRP muffler, and replaced it with a 48" donaldson (had to cut some pipe off to make it fit). i went with the 5" version as well, so i needed reducers.
i am completely happy with the result now. the muffler is still straight through (could drop a ball right thru it) but the exhaust noise is as quiet as stock, if not quieter! i was able to keep the performance/cooling of a straight pipe, yet still be nice and quiet. gotta' love that! oh yeah, it does fit on a shortbed, but it's tight . . .
the donaldson sounds like a nice set up. My resonator is open too...but I still have a muffler. As it is, its way quieter than my stock exhaust was.
To get the same thing without a muffler would be pretty sweet...
An FTE 30" resonator made the difference in enjoying my new exhaust. This was one of the threads that helped me decide to get an FTE resonator, and I'm very happy with it, so far (only installed it just this afternoon).
I bought our '05 Dodge Ram 2500 Cummins with 98k miles on it from a good friend. The tailpipe was rotting, so I decided I only wanted to do the exhaust once and I ordered an MBRP 4" turbo-back exhaust with their muffler. My goals were three-fold - better flow-through to hopefully improve fuel economy, no DOC to clog in the future, and stainless steel so I wouldn't have to replace it down the road.
The installation went straightforward. But, once the MBRP was in it was too loud for my, and my wife's, tastes. We camp in a state park a few times a year, and we really didn't want to be an annoyance when idling through the campground, either.
So I did some online research and decided to try the FTE resonator to see if that would quiet things down. Since I was going for maximum noise reduction, I decided to order the 30" version (instead of the shorter 17" version), and in stainless, as well.
It was installed this afternoon, and the difference was immediately noticed and appreciated by my wife. I would say the exhaust, besides being quieter, has a much lower-frequency primary tone, too. As others have remarked, now I only really hear the exhaust at the tailpipe, and the noise from the motor in the engine compartment is the more noticeable feature (can't get away from that one and still have a diesel, though ).
So, here's what's installed now to get this result. MBRP turbo-back 4" exhaust, including: MBRP downpipe, FTE 30" resonator, shortened MBRP short intermediate pipe, MBRP muffler, MBRP tailpipe, and MBRP polished tailpipe tip. The long intermediate pipe from MBRP was removed and is not needed with this setup, now.
That is interesting, I am going to consider trying this as my truck is noisy and gets the drone at speed and when towing.
As for engine noise, I have wanted to dynamat my interior and under the hood...since my dash is all cracked and my power seat started acting up it may be time to pull the seats out and the carpet and get the dynamat down to quiet it up...
Welcome to the site Khnitz!
I used the LMC sound deadening stuff and although it seemed to quiet things a wee tad it's pretty hard to keep those 24 valves subdued. I am seriously contemplating trying out the 48" Donaldson instead of the MBRP "muffler".
Cheers!
Mike
Cheers!
Mike
Today I installed a 4" Flowmaster system with a 30" FTE resonator and the Flowmaster muffler on a 97 12V QC LB - the exhaust is much quieter than stock.
The turbo spools a lot quicker and EGTs are down a bit.
The exhaust is that quiet that when you let the truck idle and walk from back to front it gets louder the closer you get to the engine with the hood closed- and that on a fully warmed up 12V with stock timing..
I really like it
Cheers
Markus
I really like it
Cheers
Markus
Shawn.L.Turbo
07-16-2007 06:21 PM
sled4fun
23
11-15-2006 07:02 PM
