New pump
Old 03-12-2003 | 07:08 PM
ram4fun's Avatar
New pump
I will be installing my new pump in the morning.
Got a Carter black from a place i found in Edmonton.Is there anything i should do or know before starting this.
Thank's in advance for your help .
BTW mechanical or electric for guages
Old 03-12-2003 | 07:11 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:New pump
Make sure you also get new Banjo Bolt sealing washers.
They tend to leak if you try to re-use them.
It's not that hard of a job. Should take you about an hour (for the 1st one). :
Old 03-12-2003 | 07:20 PM
ram4fun's Avatar
Re:New pump
??? ??? Now I'm confused i was thinking of putting the new pump in the frame and wirering it to the ignition.
Old 03-12-2003 | 07:28 PM
Shovelhead's Avatar
Re:New pump
OOOOOOPs :-[
I thought you were doing a direct replacement of a lift pump..........my bad.......
Old 03-12-2003 | 07:31 PM
ram4fun's Avatar
Re:New pump
Good i was starting to freak out here.thank you for clearing that out
camerd18
08-21-2008 08:20 PM
vgwood
03-31-2007 09:57 AM
jbevly
09-05-2006 04:59 PM
blh1960
02-28-2005 04:40 PM
TPilaske
16
11-22-2002 09:15 PM
