New mod questions?
New mod questions?
I just has some injector pump work done on my P7100 IP, two of the delivery valves had bad seals. While the injector pump was out I took the opportunity to have 3K GS installed and I also had them increase the timing to 16 Deg.
Now I have a few questions and one minor problem.
The problems is, when I start the truck I must tap the fuel peddle or the truck will not start. Is this due to the GSK and is it adjusted wrong?
How do I know what stock fuel plate I have? (engine has 210 HP printed on the info label)
Should I see increased power with the timing set at 16 Deg and the GSK installed? I had the truck tested at the state inspection station before the changes and after, I got no change in WOT power. Would the power increase be more at a mid range RPM and not a WOT?
My turbo wastgate opens at 22 PSI, would I need to modify this in order to get more WOT power?
They made the timing change on the injector pump and not on the engine gearing, is this a good way, and how are they different? What does the increased timing do for me?
The truck runs great and is very responsive, I love it ;D 8) But I have not pulled anything yet!
From: Used to be missoula, montana: Now in Sonoma County California
Re:New mod questions?
Idle too low i have to agree i have mine backed off and that was my resulting symtom. I am now just in the habit of tapping the throttle lightly to start the pig, and unless someone knows how to start it they have a heck of a time getting it started or running especially in the cold
D
D
Kenworth
07-15-2008 05:18 PM
jmccart
12-19-2007 01:49 AM
jamesbfishin
07-07-2007 09:25 PM
wap
14
04-23-2007 07:46 PM
RAMV
07-14-2004 01:08 PM
