New injectors & higher water temps?
Old 03-25-2005 | 11:41 AM
Haulin_in_Dixie's Avatar
Also you better watch the freeze level in the summer time or you will have a frozen and leaking heater core. Needs to be protected down to about 10 degrees even in the summer. If you have had the experience of changing a heater core, you are very careful about this, I promise
Old 03-25-2005 | 01:36 PM
RowJ's Avatar
Bill - Is it the antifreeze...or the pressurizes system that does the most to allow higher temps?
I don't really know...have always wondered.
HID - That's a great point....and one of the reasons for 25% antifreeze, which I believe is good down to about 0*.
RJ
Old 03-25-2005 | 04:56 PM
infidel's Avatar
Boiling temp vs cap pressure
0 psi - 212°F
5 - 227
10- 240
15- 250
20 - 259
25 - 267
Antifreeze also raises the boiling point, it usually says by how much right on the jug
Old 03-25-2005 | 05:25 PM
Timmay2's Avatar
antifreeze is also needed to prevent corrosion and keep the water pump lubricated....
LilBigd02
03-28-2010 03:37 PM
rjm022
09-10-2007 09:04 PM
racer-xerols
08-04-2006 04:27 AM
jerry007
10-28-2004 09:24 AM
DaNuGuy
07-06-2004 09:37 PM
