New idea on straight pipe drone?
![Lightbulb](https://www.dieseltruckresource.com/forums/images/icons/icon3.gif)
Ok we got our truck staight pi0ped yesterday.
How as expectected I can tell where the drone might be a problem. However it isnt bad empty. Just thinking ahead in case the drone gets bad. I heard the idea of a piece of angle iron strapped to the pipe. However what about using 2 performance diesel mufflers in parallel. Like 2 resistors? Would 2 mufflers hooked up side by side using a 3 into 2 2 1/2 outlets to dual mufflers back to a single 3" work? Like electronics would the resulting parrallel mufflers be less restrictive than a single 3" muffler? Just looking to be different
-Bob
![Big Grin](https://www.dieseltruckresource.com/forums/images/smilies/biggrin.gif)
![Crazy!](https://www.dieseltruckresource.com/forums/images/smilies/crazy.gif)
-Bob
The flow of air and the flow of electicity are 2 different ballgames.
To get the best flow from exhaust you want to take the path of least resistance. A straight thru muffler is the best.
Yes, diverting flow into two streams and back again will not be as effective as a straight through flow design. Every time you change diameter or change the flow direction you add some pressure drop, or in this case resistance.
J-eh
J-eh
chadrock
03-24-2004 11:31 AM
