New HX35/40
Old 03-04-2009, 09:57 PM
EBunger's Avatar
That would be an hx35 cover then wouldnt it?
Old 03-04-2009, 10:01 PM
Clunk's Avatar
Nope, many HX40's are 57-58mm. I think the new HX40 Pro is 60mm but I don't know if the inlet radius will work with the BW wheel.
Old 03-04-2009, 10:03 PM
Clunk's Avatar
Which exhaust turbine is on your SPS62?
Old 03-04-2009, 10:09 PM
EBunger's Avatar
It is the 71mm/14cm .80
Old 03-04-2009, 10:23 PM
Clunk's Avatar
I'm finishing up a S300G071 w/65mm/.70 for mine. It's a CAT piece w/61mm compressor and really-really needs to spool quick since I have a clutch pedal hanging down/ gotta re-spool on every shift.
What do you think the cm would be with a .70A/R ?
Old 03-04-2009, 10:44 PM
EBunger's Avatar
It would be a 12cm according to my old Phat shaft 62 specs which II called the 62/70
Old 03-05-2009, 04:09 PM
scottsjeeprolet's Avatar
So i'm gonna keep it. Crazydog told me i can have my 35 housing machined to fit the 40 wheel. Who knows what has to be done? Or does anyone have a 40 housing for sale?
I am also gonna have an HX40 with an 18cm exhaust for sale.
Old 03-05-2009, 06:11 PM
Clunk's Avatar
You might ask Crazydog where to get your housing machined. The BW wheel is quite a bit taller than the HX35 wheel.
You shouldn't have any problem getting rid of your HX40, they sell like crazy on eBay.
Old 03-05-2009, 06:20 PM
Clunk's Avatar
Thanks, I port matched my 14cm to my exhaust manifold and now my S300G is port matched to the exhaust manifold. I also did alot of blending & smoothing. Should be interesting. Left the CAT pipe flange alone and bell-mouthed the downpipe too.
I hope I'll have a coupla days to finish it next week.
Old 03-06-2009, 11:57 AM
Well i just got the HX40 and the compressor wheel has the clipping just like the 35/40. Now just gotta get a compressor cover.
Here's the HX40, i'm just gonna sell it because the exhaust housing is too big @ 18cm. I'm sure someone will want it on Ebay.
Old 03-06-2009, 05:02 PM
Clunk's Avatar
Check the diameter across 2 of the fins at the inducer end of the HX40 comp. wheel with your calipers and see if you get 2.359"
Firebb15
06-09-2009 08:58 PM
justagoodolboy
05-13-2008 04:48 PM
Holsteinman
09-17-2005 11:10 AM
Mike SVOR
01-18-2003 10:38 AM
shortfieldbreak
12-02-2002 08:41 PM
Quick Reply: New HX35/40
