new HG & 4K gsk, love it but have a ?
I just installed a new HG and PRD 4K gsk. It runs great and pulls good, didn't even have to adjust the idle and it works fine with cruse. If I have no load on it (not in gear) it will rev to 4K and still have more and runs smooth but under load ( runing down the road) it will start to spit and pop at 3500-3700rpm under heavy peddle. I installed the 12 new 60# springs and set the valves so its not valve prob. Do need to advance the timming? Its set at stock for now. What are some of you guys running? I have heard 18.5* on a lot of trucks but I want to here form some guys with the 4K kit. I have a stock HG for now and bolts for now and tow often. Thanks
P.S. 4K sounds good with full 5" straight and I got all my oil leaks fixed while I had it down.
Its already fun. It pulls hard all the way to 3500rpm use to fall off at 2700-2800. I want to give the new HG a few 100miles befor I get to crazy. Also need a new harmonic dampener, mine looks pertty bad. Kinda scared to hit 4K with it to many times. Dose any one have a stock one thats in good shape?
How about what I did today. 300K miles + 4K gsk + a few runs at 40+psi on stock HX-35 ( changed the location of adjustable WG fitting and didnt re set it yet usualy only 36 max I know 40 is to much) and #10 plate = BOOM
Pulled head back off and all is fine just have to do some cleaning ( inercooler , head, valves, and so on) and put on spare turbo.
What you think?
What you think?
Wow what a mess! glad nothing is really wrecked. Peirs told me when I bumped my timing that if I was going to pull regularly not to go over 18* but anything up to that point would be safe.
Big Blue24 I was thinking the same thing.
tbarbee1 thinks for the tip that sounds good I do a good bit of towing and was going to call Piers.
97dodgeram2500
15
04-14-2009 05:40 PM
SHARPMACHINE
03-06-2007 08:45 AM
MR HYDROSEED
03-09-2005 10:49 PM
Got Smoke?
10-26-2004 03:57 PM
