new guy with some questions
new guy here and I would like your input on the vp44 and TST power max3. Here is some history on my truck my first vp44 lasted 170,000kms (lucky I know) the last 2000kms of its life i installed the power max3 fueling box then it died. Now I know it was probably its time and my lift pump was not so good. So i went and found a used injector pump that was known to be good and now this pump is throwing a p0253 code. So that may mean this pump is on its way out to. i use this truck as a daily driver and i tow a heavy load with it in the summers. So hear is my questions. first from the guys that run one Is the power max 3 a pump killer. (May just be my bad luck but before I buy a new pump I would like to know what you think.)#2 If you were going to buy a pump for towing and fun as a daily driver what one would it be.
Lemon-aid Jay
P.S. thanks for your help here's what i tow
Lemon-aid Jay
Do you have a fuel pressure gauge? Your pump is cooled and lubed by fuel.
With the TST you will also need a pyro.
Lots of guys run that box on their 24v, it may be harder on the pump, but not necessarially a "pump killer"
Wire tap boxes a bit of a wild card on older VP's. Mine ended up FUBARed on the first 5x5 run on the Drag Comp I had. Don't know how many miles were on the pump. There was about 330k km on the truck though. Doubtful it was the stock pump.
For a new pump, just get a regular SO pump. I had a HRVP from II, I didn't like it. Drove poorly, idled poorly, and was a good amount more than your standard pump.
lemon-aid jay I dont know any thing about the power max 3. I run an Edge comp.,I started having the po253 code on my truck in the higher settings so I did some checking and found my problem was my wire tap on my pump.So I soldered the connection and have not had the code sense .
I like the power of the SHO pump but it idles too fast, idles rough and sounds like the truck is missing under no load conditions. You would probably like a well built SO pump. Bluechips really explains these pumps well.
Lemon-aid Jay
Lemon-aid Jay
tinker
11-26-2007 08:20 PM
IHRed
21
07-05-2006 04:27 PM
