New gauges-readings?
Old 05-29-2005 | 09:32 PM
montemorris's Avatar
Hi all.
I finally got the gauges installed-ISSPRO EV; fuel pressure, pyro, and boost. This is on a 2001 HO, 6 speed manual, 3:55 rear, no mods, 101,000 miles, new lift pump:
At 70 MPH, 2000 rpm, no load, on flat ground: FP: 14, Boost: 5, Pyro: 800 degrees.
At WOT: FP:9, Boost: 20, Pyro: 1150.
Are these numbers within a normal range?
Using the above instruments, what numbers should I strive for to obtain the best fuel efficiency?
Thanks,
Monte
Old 05-29-2005 | 10:51 PM
MadDog01's Avatar
Hi Monte,
those numbers look normal for a stock truck. Where did you mount your pyro? I've found with my 01 Ho, I get my best fuel mileage when towing my 28 ft fifthwheel between 60 and 65 miles per hour. That was before I put in my mods. We'll be leaving on a trip soon and I'll see what happens. good luck and have fun. Before long you'll probably put in some more mods.
Gary
Old 05-30-2005 | 12:17 AM
Gary,
I had all the gauges mounted on the A-pillar. I like them in this position; the're easy to read and out of the way.
Monte
Old 05-30-2005 | 10:28 AM
MadDog01's Avatar
Monte,
My gauges are piller mounted also. I ment where was your pyro mounted pre turbo or post turbo. From your readings I'd say pre turbo, Which is where you want it. If it were post turbo you want to add 2 to 3 hundred degrees to what ever the readings are. Some say 3 to 4 hundred would have to be added . That would be to much guess'n for me.
Gary
Old 05-30-2005 | 11:18 AM
Gary,
Yes, the pyro is mounted pre-turbo.
Monte
Kman9090
29
12-06-2007 07:43 PM
coontz0473
17
09-22-2006 04:52 PM
Duckman1993
09-12-2006 08:50 PM
Minnesota-Corey
01-28-2005 06:23 PM
ZR-1
30
01-08-2004 04:03 PM
