new gauges, now what to expect on boost and pyro
ok! did it with all your help,, installed gauges, not to bad,, now i'm wondering what kind of boost i should expect to have and can there be too much boost? etc,,,, and the pyro,, what can i expect my temps to be running,, installed pyro pre turbo, thanks once again for everyones help in here,, this all new to me but really liking it!! more ,, more,, more,, thats all i can think about!
Boost- You're wastegated to 22-24 psi, so you won't see more than that. Cruising arouund town empty you won't have hardly any, highway speed empty it will be 5 psi or so. If the temps climb after you reach peak boost, more boost would be helpful, but the turbo stops making useful boost after 35 psi or so. Above 35 psi it's mostly pressure gain from heating the air rather than compressing it. To add more boost, you can use a boost elbow or something similar. A boost elbow is just a calibrated leak in the boost line going to the wastegate actuator. Or you can get a TurboMaster wastegate controller like I have, lets you set the boost pressure with a 1/2 inch wrench.
Pyro- Cruising around town empty it will be 400 - 600, highway maybe as high as 900 if you're pushing a headwind. Up to 1200 is safe. Safe shutdown is 300.
bit more boost
everything seems bout like u said wannabe,,except can get up to around 30 on boost,,,is that abnormal? what will i gain with a boost elbow or the thing you have,, more power? thanks once again,, trying to soak all this in!
Re: bit more boost
If you're getting 30 psi, somebody has modified or disabled your wastegate actuator. This is not a problem, when you modify the pump to add more fuel you need more boost to keep things cool. Somebody did it already and saved you the trouble. As long as the temps are under control when you're at WOT and the boost isn't getting up over 35 psi, there's no reason to mess with it. More boost does not mean more power. As long as the temps are OK, more boost is just more resistance the engine has to push against.
No ECM on this truck, Bill must have missed that you have a 12 valve.
yea it was a typo error wannadiesel! sorry bout that,, i think the shop that modifyed the pump modified the wastegate also,,sure apprieciate all the help,,!!
Re: Re: bit more boost
Originally posted by wannadiesel
wannabe? I'm gonna assume that's a typo.
Chopper_Bob
13
01-10-2007 09:54 AM
wannadiesel
04-19-2003 10:50 PM
