New Edge Juice w 'tude installed!!!
I just finished pulling my cabover camper and wakeboard boat up Lewiston grade and all the way back to Spokane on Level 3. Only problem i had was the Attitude kept telling me my engine coolant temp was 204, never would go higher, but the analog ran all the way up to 230 before I shut it down and ran up the grade in 1st gear to keep the R's up and fan turning fast. Other than that little issue the EGT's stayed below 1150 and the engine temp between 190-200 the rest of the trip. Having that little bit extra on level 3 was all I needed to keep steaming up thhose rolling hills.
News Flash!
I just learned that my Attitude module has an old software revision and Edge is sending me another one to replace it. Apparently, Edge had a revision out there that won't keep memory according to their tech support. The problem that I had was that "turbo boost PSI" dissappeared from the display menu and I couldn't display boost pressure anymore. Nice, huh?
If you are going to buy one, call Edge and make sure you get the newest revision of your model.
JWB
JWB
I ordered my stuff from www.airflo.com Complete kit was $262.[/QUOTE]
Sounds like a good deal. Do you have a part number for that kit, I dont see it on their website?
Sounds like a good deal. Do you have a part number for that kit, I dont see it on their website? [/QUOTE]
No actual "kit" so to speak. The part numbers that I ordered are these:
(1) 26-50048CP 5" bull horn stack
(1) 45-512CP 5" chrome clamp
(2) X004484 5" band clamps
(1) 4315-450-1 Reducer, 5" OD to 4" ID
(1) 434-503PE 5" 90 deg elbow, 7.5" legs
(1) 45-PV-500CP Mounting clamp
I just made a diagram of what I wanted and pieced it together with some help from Steve at the Spokane office.
Originally Posted by 4x4dually
What was the outside air temp? What was the intake air temp? Any idea?
did you find the juice w/att locally or did you go online for it. My truck is at fentons right now getting the clutch master and slave cylinders replaced and i am looking to add a little more power when I get it back
Originally Posted by wstu
What is the recommended settings for someone who drives his truck 20 miles to work every day and pulls a 9000# boat every other weekend? The manual does not explain when you would use the different levels. I would assume you would want level 5 when pulling a boat my size up the ramp but what about on level ground. What about up a hill, or going down a hill? Going back and forward to work, do I just keep it on stock? Also is the default setting what will work best for my truck? And what are the most important things to watch for? I know that the fuel pressure is critical but what else. And are the out of box alarms and defaults set for my truck? Oh so many question, thanks for the help and sorry if these are stupid questions.
I don't own an edge box so I'll digress and let owners comment on the best settings for mileage, towing,...
MrSuzuki
08-25-2009 07:22 AM
rjm022
11-23-2006 11:29 AM
razor6
22
01-20-2006 03:43 PM
djcheez
10-15-2005 04:13 PM
