new clutch time
new clutch time
I am doing a nv4500 to nv5600 conversion here in the next week or so, so I need a new clutch (no big deal, I was getting one soon anyway) my question to you guys out there is how streetable is the MU 13-1.375 Con FE?
I would like to be able to have this clutch instead of the con ofe because I would probably push that one past its limits before I am done with power upgrades. But I do need a clutch that is fairly smooth.
I have the OFE and when backing a trailer, it doesn't like it. Tends to chatter. Other then those instances when you really gotta ride it on and off, its smooth. Great for daily driving.
I imagine the FE would be rougher.
I was thinkin a 2wd low range kit would help out the situation.
I went with the OFE but am getting ready to go double disk since I underestimated my HP goals. If I was going to go with something as grabby as the FE, I'd personally go ahead and go double disk. There is an organic faced DD that has the same hp rating as the FE but is supposed to be more user friendly as I understand it. It is more money though.
Not to rob your thread BCB, but I thought I might slip this in here because it fits (mostly). I am in the process of upgrading and in addition to what is in the sig, I will somewhat soon have Mach 4's, a Phat Shaft 64, and a TST box. What SB clutch would be appropriate for this setup? I was thinking the FE, but I would like a somewhat smooth engagement, as I ride empty mostly, but tow a small amount about once every two weeks. Any suggestions? Thanks!
Rush
Rush
Rush
Rush
Take care, Matt
I talked to Peter at Southbend and he said he absolutely tries to talk everybody out of using a dual disk that has a street driven truck. He said that the dual disk does not have a floating hub like a single disk and over time it destroys the transmission. If anybody has questions about what clutch you need call Peter as he is very knowledgeable and willing to talk to potential customers. He also told me he is phasing out the FE and has raised the holding capabilities of the OFE as well as lowered the cost. Soon I will be ordering an OFE. Eric
Rattling noise in clutch
When I start out I get a loud rattling noise from my cluch. It doesn't do it when I shift from 3rd to 4th to 5th and then to 6th. Only when I let out the clutch from 2nd. Any suggestions.
I only have 49000 miles what could be causing the rattling. I only occures when I start off.
Hmm
that rattlin u are describin could be the springs in the clutch are broken, as was the case (before further damage) to that centerjunk trash dual whatever it was i had before.. U might wanna read up on here too if ur lookin for a clutch..
https://www.dieseltruckresource.com/...d.php?t=107035
I posted a reply here..
Rick
Rush
Rush
called SBC and asked for the dodge cummins sales rep and ended up talking to woody. I told him that i used the truck to tow and my HP goals were about 500-550 amd he said that i should go with the MU 13-1.375 Con OFE he seemed to know what he was talking about. he said the ofe would hold the power just fine.
