New boost gauge, how much boost should I have ?
I just installed a boost gauge. Sitting still, in park, idling there is 0 Psi of boost. I ran the engine up to 1500 RPM for about 20 seconds, still in park, and only saw about 2 pounds of boost. Is that normal ? I can't drive it yet, I have to tighten up the exhaust clamps and get a hanger welded.
By lookin at the mods on youre sig you may not build up much boost till you start driving down the road. With youre mods you should see 20 pds of boost or more at WOT. If you still dont see over ten at WOT then you may wanna check for leaks.
i'v got a hx40 turbo in my truck. how much boost should it be making? i just got the truck and dont have any gauges yet. where can i get some. i also need my egt's gauges too! thanks
Why would anyone be runnin a 40 without fuel to spool it? And if you do have fuel enough to spool it you could have burned you pistons and or valves already...
LanceD
06-03-2010 02:13 PM
jjrightmire1973
08-12-2008 04:29 PM
Dodgezilla
20
12-30-2006 10:43 AM
wood_n_soldier
12-16-2003 06:18 PM
