New 64/14 Silver Bullet
Old 08-09-2007 | 12:09 AM
joshua smith's Avatar
Got my new 64/24 silver bullet, along with a 4gsk, SB intake, and timing set today. It is like a TOTALLY different truck. It is gonna take time to relearn how to drive it cause of the 4gsk cause the power is higher it feels like. The only thing I think I need to work on is the boost elbow cause it smokes like a freight train until it lights up, and then I only get 37 lbs of boost. Not hard to adjust though. I love the truck now!! And to think I wanted to sell it before. Oh ya, and the whistle is LOUD!!
Old 08-09-2007 | 12:14 AM
SPLnut's Avatar
did you put 60lb valve springs in?
Old 08-09-2007 | 12:18 AM
I dont know, the guys at the diesel perf. shop did it for me so I dont know??
Old 08-09-2007 | 01:17 AM
SPLnut's Avatar
I'd check into it...If I was you I wouldn't rev over 3200 rpm's till i knew...
Old 08-10-2007 | 10:54 PM
So I still cant get more than 38 lbs of boost out of this thing..... Why? I turned the set screw in but i cant get any more boost. I did have to turn the star wheel back to control the smoke cause I clouded up one too many intersections with my work trailer, but it still has plenty of go to it. What else can I do to get more boost?
Old 08-11-2007 | 12:09 AM
kas83's Avatar
You might not get much more than that for boost. The bigger turbo doesn't need to produce as much psi as it flows so much more air than a stocker. Yes, they are designed for a 1 to 1 ratio up to about 50, but if it's doing that now, and clears up the smoke, you really don't need higher psi. The higher boost number doesn't always mean more power.
texhand
02-09-2008 08:56 AM
genros
08-16-2006 10:56 AM
Syndicate
13
06-26-2006 12:57 AM
Ult680
05-23-2006 11:01 AM
Rollincoal
04-14-2006 12:22 PM
