View Poll Results: Has your VP44 failed? If so there are 4 criteria:
Did you have bigger than stock injectors?
10.58%
Did you have banjo fittings?
1.92%
Did you have a fuel box?
26
25.00%
Or were you stock as a rock?
65
62.50%
Voters: 104. You may not vote on this poll
NEED YOUR HELP **statistics on VP44 failure**
Old 10-26-2004, 12:27 PM
  #61
psalm69's Avatar
Hey fellas I only need 13 more responses to make my study more statistically sound. So don't hesitate to respond. Scott
Old 10-26-2004, 12:55 PM
  #62
Haulin_in_Dixie's Avatar
Originally posted by RCW
I do know a couple of guys that have never had a problem in 175,000 miles or so, but they generally drive empty and have trucks made for the 2002 model year.
To repeat:
Yes I lost a '99 vp44 but I did have 221,000 on it. I also had completely stock fuel lines and pump with rv275 injectors. I rarely put any conditioner in it. I had been through three lift pumps and ran 170,000 or more with no gages. All heavy pulling.
Old 10-26-2004, 08:43 PM
  #63
CarcajouCummins's Avatar
I recently rolled 250,000 miles and still on the original VP.
Old 10-26-2004, 09:52 PM
  #64
hauliday's Avatar
both times i replaced my pump was due to bad fuel Water and i was told when they check the pump and they find water they will not warranty it at that iss what i was told by the place where i got my replacement from m&d dist. in houston
Old 10-28-2004, 05:48 PM
  #65
I think I would replace the filter assy pronto. Either that or go to a FASS or Preporator.
Old 10-28-2004, 11:01 PM
  #66
RickCJ's Avatar
205,000 with oringinal vp and just replaced the oringinal lp because it would drop under 5psi wot and took too long to prime after filter change. My truck was bombed at 100k with injectors and comp. At 150k the trans was replace with DTT, the tc was slipping, the rest of the trans was still good for the miles. Only used additives a couple times,Power Service brand. My truck has been very dependable. Just got back from a 6000 mile round trip to CA and back.
Old 11-03-2004, 04:42 PM
  #67
Yamadad's Avatar
Wink
I voted on behalf of my friend, who is not a member of the forum. I hope that doesn't screw up the results.
He HAD an '01 that failed 3 times in under 100k. He got so mad he traded it in on.............. a new Duramax. Egads!?!!??!?!!?!?
Old 11-04-2004, 08:13 PM
  #68
ratsun's Avatar
Ok the list in order:
Carter pusher + stock LP =19psi @40k>
Comp less wire 92k>
Jammer IIs 95k>
Wire pierced 109,235
New pump 109,239
Old 11-20-2004, 09:35 PM
  #69
Relentless's Avatar
My 2001 just turned over 145,000 miles, is bone stock & have never replaced anything other than normal maintanence stuff.
Old 11-21-2004, 09:22 AM
  #70
Dodge Demon's Avatar
95000 KM
2001.5 ,auto,quad,4x4, 95000 KM,Canada,lift pump original 14# idle,10# hiway,got the limp mode 5 times since I bought it new,went to my dealer the other day,said it was the VP44,guess what, now Dodge is letting dealers order as many pumps as they want,no questions asked so lo and behold pumps are now back ordered at the factory,said as soon as he gets one they will slap it on and even do the fast idle,3 cyl. thing while their at it,all under warrenty,Dinsmore Dodge,Estevan Sask. Canada,superb service at all times. Running Solidsteels Dss Steering bracket, Solidsteels Track- bar Bracket with 2003 track-bar (rubber bushings both ends) drives like a Caddy.
Old 12-01-2004, 10:35 PM
  #71
JBlock's Avatar
Control Group
psalm69
Maybe you could run a control group too. Same four question without failures. That may be benficical to the study.
I have got Geno's Bangos but never have taken the time to install them and fuel guage from Andy.. I hate changing the fuel filters, the fear factor of failed lift pump. Change lthe filter ast weekend and forgot to bump the starter, I filled the fuel filter with clean diesel thank god, short story, it startd and die imedately, then would start, so I bump the switch about six ccyle. nothing. engine dead, ??? then crank the engine several more times. I was ready to change the Lift pump then caught hold and all is well.
Thanks to GOD.
Cheers
Old 12-03-2004, 07:29 PM
  #72
psalm69's Avatar
JBlock,
Really the way I have it set up, those who have not had failures are in essence the control group. Statistical Analysis, at least the way I will present it with the data given, will end up being more of a failure rate per (X) trucks with an accompanying confidence level (expressed in terms of percentage) for that failure rate.
A control group scenario would look like 10 trucks with ONE of the mods and 10 trucks STOCK.
Test for an arbitrary 50k or something and see what failed at an increased rate.
See the difference?
Thanks for the suggestion though. Scott
sooty
04-16-2009 08:23 AM
Common
03-07-2007 05:56 PM
Stew130
05-20-2004 11:34 PM
Quick Reply: NEED YOUR HELP **statistics on VP44 failure**
