Need a turbo, thinking of an Aurora 3k or 4k
Hey I really appreaciate everyones input, Im horribly indecisive when it comes to these things... First I wanted an Aurora 3k, then a Super B, then was set on an Aurora 4k, changed my mind, now I think I have finally decided to order the HTT 62/14 HTB2, seems like I hear nothing but good about HTT, and their products, plus I like the option of upgradability. Its about $500 more than the super b with no downpipe, but I already have a downpipe, so hopefully I dont change my mind again.
Super B Specials arent worth a flip in my opinion. Super B is a good daily turbo, lights and spools nice and quick but the Special is too big and LIGHTS slower than christmas. Absolutely sucks to daily drive one and no one can argue that fact, smokey is an understatement with sticks big enough to light it reasonably quick and doesnt really spool til 1800 rpm. I personally wouldnt advise anybody to get one unless its a weekend warrior or they have sledpulling class limits. The best advice I can give, drive one with a special on it before buying that turbo.
I have run 62/65/12, 62/65/14, 64/65/12, 62/65/14, 62/71/14 & now the 64/71/14. All with different injector combos & different box combos towing heavy through mountain terrain. I like to think that my feedback is worth something & I'm only trying to help. Just my $.02
Any thoughts about a Phat Shaft? I dont have one but have a few friends that have dif PS's and they have me pretty set on one.
My truck is a daily driver as well, and I tow between 4 and 14k lbs weekly depending on the work schedule.
1. they flow more air which results in cooler egts.
2. Although they spool slightly slower than a 65 series initially, they build boost way faster from 10psi to full boost. Which is what you need when trying to get a trailer moving up a hill.
At one point, I tried towing 14k# running a 64/65/14 with 200hp injectors & edge comp/Smarty stack. I had the timing advanced to cool egts, but had the fueling cut back to control smoke. I had to pull up a hill that went on for miles from a dead stop out on route 68 heading into W.V.. The turbo lit, but it built boost so slow from 10-full boost that my egts climbed faster than I could control them. By the time the turbo fully spooled, I saw 1800* on the pyro. By that time, it was too late for the turbo to catch up & I had to downshift to 3rd gear. With a 71 turbine, it spools so fast, I "beat the heat" by flowing more air & it hits full boost before my egts go over 1250*. I get rpms up to 2100 & hold them there, then watch my egts drop. I'm just trying to help you guys, take it for what its worth.
Hey J Lent I totally appreciate it, Ill take all the info I can get before I finally make my purchase. Im just worried that, although the 71 would be great on the highway and long stretches and big hills, That it will spool to slow and put out too much smoke in the around town stop and go kind of towing I do. Also I plow snow in the winter and that doesnt take much power/boost to move it, so Ill need a turbo that will get me movin right away.
Thanks for the info though.
A BD Super B Special scenario:
Towing a 10k load of cattle.... Lower gears arent much of a problem, just smokey. Around third gear EGT's will be soaring around 1400* up until you start to build boost. Turbo lights, a nasty fast spool comes on around 1700 rpm and no matter how much you try to control it....you throw the cattle down....unless you dont let it spool then you're stuck with 1400* and a ton of smoke. Just go with twins. That is the only answer unless you want to stay mild enough to run a small single. Basically a big single moves your rpm range way up. IMHO, not what the ISB was built for. Ive seen people who just love to run full throttle all the time when towing a load. Not me. Its the part throttle towing part of things that make it unmanageable. This was the case with the Super B special, Edge Comp, 180 sticks, and a smarty.
A big turbo just makes it hard to control everything while towing a big load. If you give it enough pedal to accelerate, you're gonna be rolling SERIOUS coal and once it spools you're gonna be accelerating way too fast. Not really an in between with a big turbo. If you just want ungodly top end and smoke or, then a big single is the answer.
Maybe its your gearing, but I have completely different results. My truck drives like a stock turbo truck. I do have a 3rd gen exhaust housing with 2nd gen compressor housing, but it can't be that different. I'd say that your edge box may be the culprit because it hits hard around 1700rpm.
wow
The A3000 is a 57/64 and the a4000 is a 63/70 and neither are wastegated.
I'm reading their catalog, looks like they have a kit that puts the stock turbo over the a4000 for an average power of 428hp/ 895ft/lbs hp!
I think the stock turbo could do that by itself
I did 476/936 with 125hp injectors, edge comp/Superchips stack, 62/65/12 on Dunbars dynojet.
I would have to agree that gearing probably makes a huge difference. I just saw where you have 4.10's and can see where that would keep the rpm's in a much more agreeable spot for towing. 3.55's are a bear though.... The Special is a stout turbo and SOTP acceleration is way impressive but I just dont want anyone to buy one specifically for towing huge loads and not have an idea of what it could be like.
The Super B Special was never designed to be a daily use turbocharger. Some have managed to make it work and like it. Some don't. It was really designed to be used more as your "weekend warrior" type turbo. It does not tow very well because of the lag.
