Need Turbo after jammer 5 install
Old 12-07-2007 | 11:46 PM
heykw's Avatar
I installed my edge jammer 5's on my truck and do I need to move some air I can black out a 6 lane hwy it is a lot of fun but I can peg the egts at will I was considering a single but after installing these injectors I am thinking that twins may be the way to go could any of you suggest what twins to go with and what kind of cost I am looking at Thanks in advance
Old 12-08-2007 | 12:44 AM
C2O's Avatar
C2O
first off twins are the way to go, with cost id say 4000 easy thats considering the headwork. lots of setups out there just depends what you are looking to do with the truck
Old 12-08-2007 | 07:57 AM
heykw's Avatar
Looking to go fast ha ha. I would like to be able to tow if I were to turn my box off I don’t tow very often though
Old 12-08-2007 | 08:29 AM
schoust's Avatar
Talk to J Lent I think he has the same year truck and runs the same turbo as I do and loves it makes good power and tows decent. Of course if you have the cash to go twins then by all means you should. I would have....
Old 12-08-2007 | 09:51 AM
wurkenman's Avatar
I installed my turbo after I did my nozzles. Keeps the EGT's way down over my HY. Now if I want twins I can just buy the other half.
Old 12-08-2007 | 02:36 PM
Tate's Avatar
Turbochargers.com has the BD twins for our trucks for $3400 and change, full kit, not the upgrade. There are numerous guys (RowJ comes to mind) thats making high 500's in power and still tows with them.
Old 12-08-2007 | 03:29 PM
afoulk's Avatar
Schoust, I PM'ed JLent about his turbo a few days ago, thinking it was the one you have, but he has their 61/71/14 with the cast housing. He also has 4.10 gears though, I'm sure that makes a difference.
Old 12-08-2007 | 03:36 PM
C2O's Avatar
C2O
yeah his is the 62/71/14.
Old 12-08-2007 | 07:43 PM
heykw's Avatar
Checked out Turbochargers.com dont they also make a racing set of bd twins and their is no info about what the bd twins are what psi do they run so on.
Old 12-09-2007 | 11:12 AM
C2O's Avatar
C2O
they do make a racing set. they claimed that you didnt need any head work done with the towing set so i take it those are low psi. now the racing set will get up there in psi.
Old 12-09-2007 | 11:44 AM
heykw's Avatar
summit has a bd set of twins based on the s300 that go for $2704 that seams cheap? and yes i belive that that is a full set of twins
Old 12-09-2007 | 01:20 PM
Ph4tty's Avatar
Sounds like an upgrade kit, haven't heard of the bd kits for that cheap.
Here's an example of an alternative, but you'd need to replace your hy35 with a hx35 or s300.
http://www.sourceautomotive.biz/twin..._turbo_kit.htm
Old 12-09-2007 | 02:08 PM
C2O's Avatar
C2O
wow that is cheap if its a full set maybe its an upgrade to your stocker
Old 12-09-2007 | 02:11 PM
GFB's Avatar
GFB
got a link?
Old 12-09-2007 | 02:34 PM
schoust's Avatar
OOps my bad sorry guy's anyway very similer turbo's one might spool a bit quicker than the other is all either way they are both very nice high po turbo's and a decent option if you don't have the money for twins....
sickness
03-18-2009 05:57 PM
edy
03-04-2007 02:28 PM
xOmertAx
20
02-17-2007 10:52 PM
skargo
24
05-24-2006 09:39 PM
natlchamp2k4
16
02-22-2006 04:39 PM
