need studs with nitrous?
Old 11-05-2007 | 10:10 PM
bskrenn's Avatar
My dad is going with a nitrous kit and he is wondering if studding the head is nessesary. I said that it is and he doesn't. Please give me some insite on the topic.
Old 11-05-2007 | 11:38 PM
Big Blue24's Avatar
What kind of truck does he have? Year, mods, etc. A stock truck could hand a 20HP shot of nitrous no problem. A truck on the edge with stock head and studs could not handle 20HP shot of nitrous. No stock truck could handle a 200 HP shot! So lots of variables, if you give members the whole picture, you will get better feedback.
Old 11-12-2007 | 03:38 PM
bskrenn's Avatar
He has a 99 with a comp box, jammer 5's, httb2 62/71/14, k&n intake, CFM+ intake manifold, full billet tranny.
Old 11-12-2007 | 11:48 PM
Big Blue24's Avatar
Yeah, he will need studs, in fact, I can't believe his head does leak as it is. Does he thrash on it much?
My old man never hot rods, he could run nos, meth, twins, and Mach 8's with a stock head and a stock tranny!
Old 11-12-2007 | 11:57 PM
displacedtexan's Avatar
I would stud it if it is his DD...
Old 11-13-2007 | 12:18 PM
Jetpilot's Avatar
He needs o-rings or fire-rings to run nitrous!
Old 11-18-2007 | 07:48 PM
bskrenn's Avatar
My old man is worse than i am! He cant drive it without smokin someone out. His Liscense plate says "SMOKINU"....HEHE I think i am goin to talk dad into a cosmetic hg and get him to stay away from cuttin up his head and block. he just wants the nitrous to get the edge over a certain person at our next local dyno days. Dads pickup is in Diesel Power Mag (december 2007) pg. 138 and 143. His name is mark.
Old 11-18-2007 | 07:50 PM
Jetpilot's Avatar
I would stay away from the Cometic gasket..... I have fielded about 10 calls in the last 2 weeks from blown Cometic HG's. Appears they are not all olding as advertised.
Old 11-18-2007 | 08:04 PM
bskrenn's Avatar
Thanks for the insite...u think that studs on a stock hg will hold up?
Old 11-18-2007 | 08:06 PM
HOHN's Avatar
Are those Co(s)metic ones just for looks?
Seriously, what do you suspect is the problem? Surface prep? Clamping force? Gasket design?
Justin
Old 11-18-2007 | 08:14 PM
Jetpilot's Avatar
No, not with nitrous....
Old 11-18-2007 | 08:17 PM
Jetpilot's Avatar
Justin,
I wish I knew..... The guys I have talked with told me how they prepped the surface and installed the gasket and it all sounded good.
On another note did you see the article in the TDR mag on replacing a II PS62 with a garrett GT37 from Turbo re-source? Pretty interesting, picked up HP and TQ, also hit peak number 200-400 rpm lower! Egt's were down 100* for the same run and higher HP. The turbo is pretty much a direct bolt up except for the H2O lines.
Doug
Old 11-18-2007 | 08:19 PM
bskrenn's Avatar
ok looks like my moms will have to cut down on her hair app and my dad needs to cut down on beer...yeah right!!
Old 11-18-2007 | 11:45 PM
Ph4tty's Avatar
Justin,
Doug
Fantastic info Doug
Old 11-19-2007 | 02:40 PM
Moose10's Avatar
Hey bskrenn, do you know where to get N2O filled locally?
