Need some advice on injectors/nozzles
Okay all, I need some advice. I just had my VP44 replaced under warranty and am now at 99042 miles. I want to upgrade my injectors. I pretty much have a stock truck but it is a HO which I've heard makes a real difference when it comes to injectors. Here are some questions:
1. I'm leaning towards edge jammer I or II nozzles, would these be good for my application?
2. I don't want to smoke out the neighborhood or upgrade my turbo
3. Should I buy the whole injectors or can I get by with nozzles?
4. I want to eventually buy a smarty tuner, should I stay away from any injectors for that reason.
5. I don't want to spend a fortune here guys, I just want something with a little more punch from the skinny pedal.
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
Stage 2 nozzles and a used ez can be had for less than 500 bucks if you look around. Also like Dzlfarmboy said, address your fuels system first.
The main question is how much $$$ do you want to spend?
Hummin Cummins
10-20-2009 01:52 PM
benroberts3605
03-05-2009 07:54 AM
bsj04
09-20-2007 09:09 AM
ryan466
08-30-2006 11:10 AM
MonroeDiesel
08-29-2003 10:36 PM
