Need opinions on 12cm vs 16cm exhaust housing
#47
Originally Posted by G1625S
Modding the 12cm housing is fairly straightforward. The wastegate only wastes the rear three cylinders, which is fine for stock fueling.
With the housing off, you can put it in a drill press and drill through the existing wastegate hole and through the center divider. Now, when the gate opens, all 6 cylinders 'see' the gate, allowing more exhaust flow without increased boost. Some have taken this a step further and milled the center divider out almost completely.
I'm gonna give this a shot tomorrow. With your current setup, a massaged 12cm housing with an upgraded compressor side would make for a fun truck, for sure!
How does one mod the compressor side of a HX35 stock turbo ??
#48
Originally Posted by Katmandu
Sounds great!! Take Pics for us and let us know how it goes!!
As for the compressor side, talk to Paul at HTT (or other vendors, if you like). For a couple hundred bucks you can upgrade to a larger pinwheel and housing. There are no free modifications to be done on the compressor side. Tolerances are too tight to 'eyeball' anything.
greg
#50
Where does one buy this Marine wet rubber exhaust hose stuff ???
PS this hose can replace your upper intercooler boots too. Burst pressure for 3" I think was about 275 psi.
#51
Originally Posted by doodah
How much $$$$ are we talkin about with this filter??, what do you think you have invested in the other stuff for this setup? box,hose,etc,etc,??
2) hose maybe $6 - $10 bucks a foot for either hose
3) battery boxes can really vary in price. Avg. up here for a plain ol' box group 27 box is about $12 - $20, ofcourse everything up here usually costs close to double of what it costs down below.
Firstgenfanatic
08-17-2008 11:25 PM
ajbirken
09-06-2006 12:11 AM
HOHN
12-07-2003 02:07 PM
