need more power
Old 11-22-2005 | 10:33 PM
95dodgeram21's Avatar
Question need more power
I am installing twins on my 95 5-speed I think i got the install under control
But i want more power what can i do to the pump I've got:
175 hp pump
370 marine injectors
191 dv soon to have lazer cut
#0 plate
Going to have the rack travel set at 21mm
the pump is off the truck (do to tapet cover leaking)
and going to a good pump shop here local to have the rack travel set
So what else can they do while they have it at the shop
Thanks Dean
Old 11-23-2005 | 10:58 AM
northslope's Avatar
Just tell'em you want maximum boom I'm not a pump pro but all I could say is probably a given and the shop will probably do is: 4k gsk's, & afc springs & jack the timing if it can be done, on the bench.
Old 11-23-2005 | 11:12 AM
I forgot but I've already got the 4k and gutted the afc
I just wanted a little more info so if they dont suggest somthing i can
Thanks Dean
TDRattler
07-12-2008 08:42 PM
dieselJon
07-22-2007 01:39 AM
robox
10-18-2005 08:38 PM
j
12-21-2003 11:26 AM
