Need to know how to messure turbo size
I have an hx40 and pu a dial caliber thats in mm, wanting to know what size exhaust housing I have on there. I thought you check the inside edge of the housing right, but numbers dont look right. 81.83mm now I need to covert that to cm right. so what do I have then.
Inside the turbine inlet, but its usually stamped outside of the housing as well, generally on the back of it. Its not based on the exterior size. Some H1C's came with a 21 cm housing, but physically was much smaller than the 22 cm housing on an HT3B.
Found it, right where you said it was on the inside of the manifold housing, covered with blk exhaust. and it is a #16. that must be way I have alittle more lag then I want in take off. tate thankyou for the help. was on another site and didnt even get 1 response to my question. thx again.
If you go to the Holset website at: http://www.holset.co.uk/mainsite/files/ they have a lot of information available to download in .pdf format, including Holset Service Manuals and contact information with phone numbers.
TayTay
69
05-13-2015 03:42 PM
2007Dually6.7
0
05-18-2010 08:28 PM
