Need help quick with fuel pressure!!!!
Does this pump have the same inlet and outlet fitting as the stock LP. I have the Vulcan kit and dont want to stick another stocker in there. But right now I have very very litle FP so I need an answer quick. If this one doesnt I dont have time to wait on conversion fittings right now. Is there another pump that I can just bolt up to the stock fittings???
Thanks alot,
guy in distress
Jamie
http://store.summitracing.com/partde...0&autoview=sku
Thanks alot,
guy in distress
Jamie
The 3/8 NTP threads are not stock but they are a standard fuel fitting size like a Holley Carburetor, available at your auto parts store. Plumbing them in,
with your Vulcan kit on the fuel filter and VP will be fine. Hose & clamps on mine.
I use the 2 extra Vulcan fittings on my old stock/spare pump. Now I don't know about the electricals though.
Here's an informative thread concerning the Campain Pump.
https://www.dieseltruckresource.com/...090046+cummins
First you say you have the pusher kit,did that add a second pump or relocate the stocker. Second if it is a scond pump putting the aeromotive pump in there will be way to much pressure, it says it is 150gph at 16psi ,that will be over 40 psi at the vp44 if im right(speaking from exp.). If you have eliminated your stock lift pump and its location than you will be fine. As far as instalation rubber(fuel) hose and hose barbs will work fine, thats what i use and no probs.
I talked to eric at vulcan and he did used to send 3/8's adapter with his kits so I have all I need and I just ordered the areomotive pump. Thanks for the help guys,
Jamie
Jamie
mr. ed
01-07-2011 10:08 PM
8mpg
19
02-26-2007 04:14 PM
HorseHauler
13
03-12-2006 11:48 AM
MoparRiggan
01-05-2006 11:09 AM
