Need help!!!, fuel in oil after installing injectors.
Just put in my Jammer 3s today, they were complete injectors in a pop tested and balanced set from city diesel.
I took the truck for a test drive and i love the added power but on the way home i noticed my oil pressure was down a bit. Much to my dismay there was fuel mized in with oil on the dipstick!!! I must have tightened down the fuel line nuts too much into the head ? Or Maybe the injectors aren't set enough into the head ? I torqued the 8mm nut that holds down the injectors to 89 inch pounds (from the diesel dynamics injector install instructions) but it didn't seem very tight.
I'm not sure where to start at this point, should i buy new crossover tubes or is it difficult to pull out and inspect them ? should i pull the injectors as well? I don't know if one or all of them are leaking!
Talk about a mod job gone terribly wrong! i don't even know if the local dealer would stock crossover tubes!
When I did my injectors I put a wrench in the slot on top of the injectors and kind of turned them back and forth while pushing on the supply tubes to make sure they were seated in the tapered hole. Probably where you have a problem. Try to retighten your injector lines at the supply tubes and see if you get any movement.
o-rings on the injectors were new but i didn't touch them on the crossover tubes. I'm going to try and buy a set of tubes and o-rings today and replace them tonight, i have the feeling i tightened the injector lines too hard and buggered a tube.
YIKES! i called the local dealer and the connector tubes are $75 a pop!!! i think i'm going try re-torquing injector hold down bolts and pull out and inspect the crossover tubes...
There's only 3 ways fuel can get into the oil.
1 is a bad injector spraying too much fuel and its getting past the rings.
2 is a bad o-ring on the injector, the connector tubes have nothing to do with this.
3 is the injection pump input shaft seal, unlikely as you haven't touched this and you just did injectors.
Maybe you nicked one of the big o-rings on the install. The connector tubes have their own o-rings, but thats to keep fuel from leaking out to the outside.
If you damaged a crossover tube, you would definitely have a bad idle. My guess is oring on injector or fuel mixed with oil when you did the work but now no more leak.
Is the oil level increasing? If not, change your oil and see if you still get fuel in the oil.
It would leak fuel into the return system. Unless you have a restriction in the return line and its letting the pressure build up in there and then it would leak past the o-rings, but they should at least hold a little bit of pressure.
Couldn't you pull the valve cover off, run the truck, and look for fluid coming out of the injectors? At least you can narrow it down to which one is leaking, so you don't have to pull them all.
Everything seems fine after a test drive so hopefully theres no more leaks!
Warhawk22
05-16-2010 11:43 PM
