Need help deciding...
I am getting ready to order a boost gauge (if it snows tomorrow -$). I can't decide between a 35 psi or a 60 psi unit from Autometer. I plan on running 370's and delivery valves in the spring, along with a hybrid kit from HTT turbo. I know that running a stock turbo up into the 30+ psi isn't good for longevity, what about the hybrid kit, will it make the turbo able to handle higher pressures? I also *may* run a water injection kit depending on how bad egt's are. How much boost would you folks assume I would have with the injectors, DV's and hybrid turbo? I only want to buy a boost gauge once... If it's worth anything, it's my daily driver and will pull 4-12K+ around in the summer, as well as sled pulling, so it has to be somewhat reliable. Thanks in advance!
Intercooler
06-02-2005 08:28 AM
PowerstrokeThis
05-18-2005 04:31 AM
