need help in choosing a large single charger
I Have a 94 5spd and I would like some help in choosing a turbo.
I have new era 435hp injectors,0 plate, mack plug, full cut dv's,23* timing,12mm studs,o-rings, 5kgsk.I do have more fuel coming so I need to be able to have a little room to grow. I am hoping for 500-600hp on #2 only. I drive it everyday and sled pull maybe a dozen times a year. I would like to stay with a single charger with 2.5-2.8 inducer if at all possible.
Sorry for the long post. Thanks in advance.
2.5 to a 2.8 is a big gap in charger size really. A SPS64 with a 14cm housing would probably be a good all around turbo for you, but if you want to go 2.8 you are gonna be looking at a lot more lag, but once it lights, it'll clear the smoke a lot better. Just do some research and figure out if you want spoolup or all out performance.
Eric
Eric
OutOfSight
11-07-2008 07:54 AM
Bean
09-25-2008 04:06 PM
5.0 Mustang Man
38
09-19-2008 03:01 AM
Bswope
17
04-28-2008 02:29 PM
pcburnout
09-07-2005 08:25 AM
