Need guages in what order
Re: Re: Need guages in what order
Originally posted by mkubacak
You can use these to get all four in a three gauge pod. Combo Boost/EGT, Fuel Pressure, and Trans Temp.
Thanks
Bill
Originally posted by 2500Ram
I looked but didn't see where you have yours mounted. Maybe I missed in on the A Pillar pics but all I found was the gauge and fittings.
Thanks everyone for the great advise.
They do cut into the vision somewhat, but you get used to them. You might have to actually lean forward in your seat to make sure you get a clear view of things...like at a stop sign or something.
I also have an '02 2500.
Looks like 4 gauges are better then 3, or get the 3 with Fuel Pressure light,
Which brings the question. Some a-pillar installs show 2 gauge partials.
Has anyone place Two - 2 gauge partial A-pillar installs together for a 4 gauge effect.
Is there room?
Is there room?
Is there room?
Is there room?
I'd have to vote a big NO on the fuel pressure gauge light...that will only tell you when you're already at a critical stage...wouldn't you want to see that you're heading there? Also what happens if that bulb ever burnt out or stopped working
![Crazy!](https://www.dieseltruckresource.com/forums/images/smilies/crazy.gif)
jmccart
08-02-2007 12:35 AM
phox_mulder
20
04-05-2004 07:55 PM
dealseeker
15
12-17-2002 06:43 AM
