Need a couple more Beta testers with stock to mild trucks
Old 06-25-2007 | 12:49 PM
  #61
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Originally Posted by SR_Crewchief
Quad,
Box arrived Friday. Had a weekend from hell though, work related oncall not the beta XZT, so I haven't installed yet. That will be correct nlt tomorrow.
Got a couple of questions:
The switch appears to be a standard 3 possition type. But is not marked, nor covered in the installation instructions, indicating which position is for which setting. Once installed experimentation will reveal, but it would be nice to know ahead of time.
What is the most common means of routing the wiring harness into the cab? New hole or existing one?
Thanks
Mine had a lone "E" for the economy posistion, stamped or paiinted on the rubber-heat shrink stuff alone the side.
Old 06-25-2007 | 12:59 PM
  #62
JPR Ram's Avatar
Quad,
Thanks
There is a rubber plug just above and to the side of the the brake peddle assembly. It kinda looks like a football shape. Two plastic plugs hold it in place. Puch the plactic plugs from the inside of the cab.
Old 06-25-2007 | 01:38 PM
  #63
JyRO's Avatar
My box arrived on Friday also. I wanted to check back here on the best way to go through the firewall too.
JPR - That football shape, it's from your 2000 model right? Mine is a 2000 model too. I don't remember seeing the shape your talking about. Can you describe it and it's location in more detail. Thanks.
Also, my switch did not have a nut on it. The flange is threaded, but no nut. I bet a small / thin nut to fit that may be hard to find at the hardware store. Quad - Anyway to get a nut or two put in a baggie in a regular envelope?
Lastly - Where do you guys think you'll put this switch? I like my stealthiness, so what I was thinking was to put the switch on the ashtray upper surface. When the ashtray was closed, you would see nothing. Open the ashtray, and switch is oriented with the lever down(ish) flip the switch to where I want it and close the ash tray. How does that sound?
- JyRO
Old 06-25-2007 | 01:55 PM
  #64
JPR Ram's Avatar
- JyRO
Looking from inside of the engine bay, it'll be behind and above and to the right of the master cylider/brake booster. It's kinda hard to see. tight quarters and all. But it is there.
As where to mount the switch, I haven't found a spot I like yet. So it's just dangleing around the steering colmn and auto shifter for now.
I was thinking of using the ash tray door and building a fuse/control switch panel for it and maybe for aux lights and such. I just don't know yet.
Old 06-25-2007 | 01:57 PM
  #65
qzilla's Avatar
Did you get your new box yet JPR??
Old 06-25-2007 | 02:00 PM
  #66
JyRO's Avatar
I did a search, seems like the area your talking about is the grommet used in the slushbox trucks. Mine is a manual tranny. I don't think I have that. The grommet for the main wire harness has some room, looks like I'll cut a slit in it.
- JyRO
Old 06-25-2007 | 02:02 PM
  #67
JPR Ram's Avatar
No. I'm kinda expecting today or maybe tomorrow. You guys recieved it last thursday, according to Fed ex
Old 06-25-2007 | 02:18 PM
  #68
dieselbeef's Avatar
Muted User
i am intersted in being a testor if still looking.
i do all my own work also so i have a fair knowledge of whats goin on with the truck most of the time....
i have a 33 mi ea way commute to work 7 days a week.
i also do a considerable bit of towing above 10000 #.
thanks
Old 06-25-2007 | 02:25 PM
  #69
CARR's Avatar
I am intereated PM me.
Old 06-25-2007 | 02:37 PM
  #70
5.9Shaker's Avatar
I will give it a try
Old 06-25-2007 | 07:53 PM
  #71
9 sec camaro's Avatar
Im like Jpr my switch is jammed between the dash and the gauge pod. I did not get a nut with my box also no big deal I will go to radio shack and buy a small switch and take the nut from it. I was thinking of mounting my switch in my gauge pod that runs down the pillar I also mounted my low fuel pressure light there I am not a big fan of drilling holes. And im the one stacking with the banks box.
Old 06-26-2007 | 08:52 AM
  #72
mudman78's Avatar
The box was sitting on my front porch when I got home this morning . Same deal, no nut for the switch and the switch isn't labeled or identified.
I'm swamped at work and won't get it installed until Friday. Can one of you guys that has it in, in the next couple of days post the wire color/switch position so the rest of us won't have to guess
Old 06-26-2007 | 02:37 PM
  #73
JPR Ram's Avatar
It's kinda hard to see because of the heat shrink, but it looks like Red wire is economy, white being tow and green being the performance.
Old 06-26-2007 | 03:42 PM
  #74
Black sheep's Avatar
I'm willing to give it a try.
Old 06-26-2007 | 03:57 PM
  #75
JyRO's Avatar
As far as the switch orientation, I'm going to let my butt be the confirmation. If I don't like the orientation of the switch, I'll loosen the nut and turn it.
