need an ATS manifold with twins?
Old 08-04-2005 | 01:49 AM
LanceD's Avatar
I read somewhere that they recommend you use an ATS manifold with a twins setup, why is this?
Old 08-04-2005 | 02:02 AM
ratsun's Avatar
The ATS manifold in my (Piers) set-up needs to be flipped upside down for extra clearance. Also the ATS unit is a really heavy duty and sturdy (compared to the stock one) so it helps support some of the added weight.
Old 08-04-2005 | 05:43 AM
LanceD's Avatar
so you can't flip the stock manifold and build a bracket to support the big turbo? I am just curious, and trying to save a little $$ without sacrificing power
Old 08-04-2005 | 06:58 AM
CTD NUT's Avatar
Yes, you can flip the stock manifold to use it in a twins set up - many people have.....but the stocker is marginal at best and is prone to cracking from excessive expansion and contraction from heat cycling. The ATS manifold is much more durable and is considered to be superior to the stocker, if you are running twins or not.
Old 08-04-2005 | 05:31 PM
LanceD's Avatar
would it be bad to run the stocker until it cracks and then get the ATS?
Old 08-04-2005 | 05:44 PM
Marine's Avatar
Since you are already going to have the stock one off to turn it around, why not just put the ATS on? It will save you the aggravation of taking the twins apart again.
Mike
Old 08-04-2005 | 08:52 PM
LanceD's Avatar
because isn't that manifold like $400+? I would like to save as much as possible until I really need it. I could spend that 400 on a nice wastegate
Old 08-04-2005 | 10:28 PM
Marine's Avatar
It is pricey, but I wouldn't dismiss the idea.
Mike
Old 08-04-2005 | 11:16 PM
joefarmer's Avatar
I used the stock manifold for a year and a half. The B2 had a support bracket connected to the NV4500 bellhousing adapter plate. I never had an issue with cracking. Even with twins, changing manifolds wouldn't be that hard since you've had it off once. Depending on the twins setup, you may look at 2-3 hours to replace the manifold once it cracks.
brandon.
Old 08-05-2005 | 01:42 AM
BoostdCTD's Avatar
I think the cheapest I've seen the ATS manifolds are about $380 on eBay.
Old 08-05-2005 | 01:20 PM
justinp20012500's Avatar
brandon.
I have been using the stocker for a year and half also. My BHT3B is supported off the block where the heat exchanger once was.
After doing a few different twins the disassembly is not that bad. A couple of beers and about 2 hours and your done...
Justin
Old 08-05-2005 | 01:35 PM
RowJ's Avatar
I think a stock manifold would work, with extra support from below for your big turbo ...but I would get an 01 or an 02 manifold. Much stronger and less prone to cracking.....available for $100.00 +/- in classified ads...either here or on TDR.
RJ
dodgediesel
ABDTR #5
10-18-2011 10:22 PM
dodgediesel
ABDTR #5
496
10-16-2011 05:33 PM
Dieselhed
04-10-2008 02:05 PM
Stock 02
28
09-24-2006 12:09 PM
smittybuilt
01-08-2005 12:32 PM
