Need air filter to flow 12-1500 CFM (90-105lbs/min)
I'm trying to source a foam filter capable of flowing 12-1500 CFM @ 80F @ sealevel (90-105 lbs/min). It should be 5" ID inlet. Anyone know where to source one? I tried UNI and they acted like I asked for a cat dipped in pancake batter. I didn't like the film of grease/dust the aFe gauze filter left in the intake tube of the last truck. Does Nelson or Donaldson make a paper filter in this range?
Thanks!
bnraond.
Thanks!
bnraond.
Donaldson has 6-7 filters that will flow that kind of air, but I don't know where you're going to put it
http://www.donaldsonfilters.com.au/u...placements.pdf
I'm only running 1 battery, I suppose I could stuff one of those on top of the fender and no one would know the difference. The other option Chris pointed out was to use two filters in parallel. CFM would be met and I could still throw in the second battery if needed.
brandon.
brandon.
Originally Posted by sleds
bnroand, you spelled your name wrong in that last post.
brnadon.
diesel yukon
12-19-2011 05:45 PM
ralphyboy
01-17-2008 08:35 PM
dieselpower04
08-18-2007 04:48 PM
